Date/Time: Sat, 01 Mar 2025 07:11:32 +0000
Instance #3 Keeps crashing when I have NQ chart
View Count: 498
[2021-09-26 00:50:13] |
DayTraderEsad - Posts: 121 |
When I load simple chart without any custom studies NQ chart stops updating half way and then the entire instance freezes and ends up crashing. It only occurs when I have a NQ chart, but if I do it without the NQ, it works just fine. I normally keep RTY, ES and NQ chart on at the same time. The same chartbook works with no issues in the main Sierra Charts, nothing crashes. How can I fix it for the 3rd instance?
[2021-09-26 16:47:23] |
John - SC Support - Posts: 38292 |
We want you to delete the NQ intraday and daily files in that 3rd instance. Follow these instructions (again, just in the 3rd instance): Chart Data and Chart Data Files: Deleting a Chart Data File Then open your charts as normal in that instance and it will redownload the data for NQ. Let us know if this resolves the issue for you. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2021-09-26 17:08:01] |
The issue could also be caused by incorrect Chart Settings or some issue involving a study.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2021-09-26 17:08:15
[2021-09-26 17:37:46] |
Deleting the NQ files actually worked, it loaded up perfectly. Thank you for your help on this.
