Date/Time: Sat, 01 Mar 2025 08:50:17 +0000
Data/Trade Service Settings for Rithmic (SC ver 2310)
View Count: 575
[2021-09-25 18:42:38] |
DGee - Posts: 82 |
There is no selection in the server list for MES Capital. Previous versions did. Please advise. Thank you.
Date Time Of Last Edit: 2021-09-25 19:22:50
[2021-09-26 16:34:59] |
John - SC Support - Posts: 38292 |
You would need to ask MES Capital about this. Rithmic has control of the list of the servers, which is why it takes us a minute to initially get that data from them when you are first setting up the connection.
[2021-09-26 17:02:11] |
DGee - Posts: 82 |
Revert back to ver. 2308 and have my connections back.
[2021-09-27 17:18:33] |
Sierra_Chart Engineering - Posts: 18607 |
This relates to the information here: https://www.sierrachart.com/index.php?page=doc/Whats_New.php#SCVer2310 (version 2310) We have asked Rithmic what particular server you should use for the new connection. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
