Date/Time: Sat, 01 Mar 2025 07:05:06 +0000
Cluster Filter
View Count: 1026
[2021-09-25 15:41:41] |
Daniel Widmar - Posts: 24 |
Hey Guys, i'm looking for: 1. Volume Cluster Indicator ( see attached File ) 2. Big Trades ( Filter Big Volume ) 3. Stacked Imbalance 4. Unfinished Auction thanks. |
[2021-09-26 16:29:50] |
John - SC Support - Posts: 38292 |
1. This looks like the Numbers Bars study. Refer to the following: Numbers Bars 2. Refer to the following: Volume at Price Threshold Alert V2 Also refer to the following: Chart Settings: Volume Filter (Chart >> Chart Settings >> Data Limiting >> Volume Filter Settings menu) 3. Refer to the first link in #2 above, there is a section at the bottom related to Stacked Imbalance. 4. You would have to set this up in the Numbers Bars study. Refer to the first link above. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
