Date/Time: Fri, 02 Oct 2026 13:21:17 +0000
SC2210 - issue with moving bracket orders
View Count: 859
[2021-09-24 21:31:16]
Kiwi - Posts: 375
Yesterday I noticed a problem when moving a chart entered limit entry with stop limit brackets on 2210. So I dropped back to 2296 which was error free.
Today, with the market closed I updated to 2213 in case something had changed.
I place the order ok & it shows entry + the two exits.
I move the order and get this message:
Trading message from IB: Error validating request.-'bO' : cause - The size value cannot be zero:. Error Code: 321. ServiceOrderID: 69. InternalOrderID: 7387. | 2021-09-25 07:28:11.387 *
Order modification failed | Error validating request.-'bO' : cause - The size value cannot be zero:. Internal Order ID: 7387. Service Order ID: 69. Symbol: HSI-202109-HKFE. Account: U7xx | 2021-09-25 07:28:11.387 *
Trading message from IB: Error validating request.-'bO' : cause - The size value cannot be zero:. Error Code: 321. ServiceOrderID: 70. InternalOrderID: 7388. | 2021-09-25 07:28:11.387 *
Order modification failed | Error validating request.-'bO' : cause - The size value cannot be zero:. Internal Order ID: 7388. Service Order ID: 70. Symbol: HSI-202109-HKFE. Account: U7xx | 2021-09-25 07:28:11.387 *
If I remove the brackets (x after placing the order so they are cancelled) and I'm just moving the original there is no issue. If I drop back to 2296 there is no issue.
For your attention thanks.
Date Time Of Last Edit: 2021-09-24 21:36:08
[2021-09-27 09:48:08]
Sierra_Chart Engineering - Posts: 25027
We are looking this over.
[2021-10-06 03:14:56]
Kiwi - Posts: 375
Did you have any luck with this?
[2021-10-06 03:52:14]
Yes this was resolved over a week ago.
Update to the current version following these instructions:
Date Time Of Last Edit: 2021-10-06 03:52:32
[2021-10-06 07:14:17]
Kiwi - Posts: 375
Confirming that on 2318 there is no problem anymore.
Thanks.
