Date/Time: Sat, 01 Mar 2025 14:04:00 +0000
Is it possible to Build an S&P 500 Heatmap like on FINVIZ with your software, Y or N ?
View Count: 3896
[2021-09-24 17:37:49]
GravisHTG - Posts: 306
I Just want the simple answer , YES or NO
no need for all the other fuzz and links.
thanks in advance
And I still have to know my A - B or C answer to my other post !!!
I keep it really short for you guys now , Because I know , you are very very very very very ... BUSY ( and %#$%@$% for long questions ) !
Date Time Of Last Edit: 2021-09-24 20:31:07
imageheatmap.PNG / V - Attached On 2021-09-24 17:36:16 UTC - Size: 141.23 KB - 640 views
[2021-09-25 15:58:01]
hanw - Posts: 15
I would say no. How is it useful for trading?
[2021-09-25 17:55:34]
@ hanw
This can be use as another Indicator to give more Strengh to your Idea.
And with the way finviz do it , its fast to see the whole picture.
And If we can build it under sierra chart , that mean we could customize it for any Stock, symbol , future, forex we want.
[2021-09-25 21:46:50]
Kiwi - Posts: 375
You could pipe your data to Python and write code to create such an image (don't know which graphics package you'd use). But if you're doing it in Python already why not take the stats directly from your broker if they've got a suitable API.
[2021-09-25 21:47:58]
Kiwi - Posts: 375
Actually, here is a howto
https://www.economicsandcoffee.com/2020/12/12/building-a-heatmap-of-stock-market-returns-for-sectors-with-python/
[2021-10-08 15:58:04]
No, this is not supported what is being looked for.
