Date/Time: Sat, 01 Mar 2025 06:52:29 +0000
How to highlight volume > threshold(integer) for bid/ask volume in footprint
View Count: 1742
[2021-09-24 11:17:23]
Stav - Posts: 104
Hi Sierra Chart,
I have tried everything but to no avail. I've looked at the documentation.
How can I choose to highlight volume say greater than 500 for at any price level on my footprint.
I can't see where I can choose dominant bid/ask vol > 500 (say) [column 2] and set that to a certain colour.
Would really appreciate some help on this.
Thank you.
Stephen
imageSettings 1.png / V - Attached On 2021-09-24 11:15:46 UTC - Size: 69.03 KB - 358 views
imageSettings 2.png / V - Attached On 2021-09-24 11:16:06 UTC - Size: 68.96 KB - 289 views
[2021-09-24 13:11:36]
User907968 - Posts: 833
Background
Numbers Bars: Background Coloring Based on Volume - Actual
Numbers Bars: Background Coloring Based on Dominant AskVol BidVol - Actual
Text
Numbers Bars: Text Coloring Based on Volume - Actual
Numbers Bars: Text Coloring Based on Dominant AskVol BidVol - Actual
Actual Thresholds
Numbers Bars: Column # Actual Volume Compare Thresholds
Date Time Of Last Edit: 2021-09-24 13:11:56
[2021-09-24 18:11:26]
John - SC Support - Posts: 38292
There is not a specific Highlight Values Greater Than setting for the Numbers Bars. What you would need to do is to use the Text Coloring methods and set your thresholds as needed to color values above a certain level the color you would want.
Refer to the following:
Numbers Bars: Column # Text Coloring Method
And also the following:
