Date/Time: Sat, 01 Mar 2025 08:10:43 +0000
Background coloured area
View Count: 556
[2021-09-24 01:08:40]
Ben A - Posts: 123
Is there a way of to colour the background of a specific area in a rectangle instead of the rectangle tool so that I am able to still use the hand tool to drag the screen with wider rectangles?
Would the only way be transparent background fill between two horizontal line studies?
Thank you,
Date Time Of Last Edit: 2021-09-27 15:19:29
[2021-09-27 19:33:50]
Ben A - Posts: 123
Thank you
[2021-09-27 23:28:57]
Tonkadad - Posts: 235
The easiest (I think) would be to create 2 toolbar buttons (rectangles) with different color configurations.
You can adjust them independently.
Chart Drawing Tools: Creating Control Bar Buttons which Select Drawing Tool and Drawing Tool Configuration in One Step
Chart Drawing Tools: Drawing Tool Configuration
Date Time Of Last Edit: 2021-09-27 23:30:32
[2021-09-28 00:01:12]
Ben A - Posts: 123
This is the issue, I cant use this drawing tool because when using this and wide rectangles, I cannot move the chart using the hand tool otherwise I would use the rectangle drawing tool
