Date/Time: Sat, 01 Mar 2025 07:24:21 +0000
Sum of contracts in each bar, on Footprint
View Count: 490
[2021-09-23 20:04:16]
User674409 - Posts: 24
Hello, is there anyway that, the footprint can display above o below each bar the sum of all the contractos of each bar? I attach an image, to explain better myself. You can see that the total from one side is 428, and the other side is 296 Thanks
Private File
[2021-09-24 16:42:12]
John - SC Support - Posts: 38292
What you want to do for this is use the Bid volume versus Ask Volume study or the Numbers Bars Calculated Values Study, which will give you the sums. Refer to the following for the Bid Volume Versus Ask Volume:
Bid Volume vs Ask Volume
And refer to the following for the Numbers Bars Calculated Values:
Numbers Bars: Displaying Numeric Information Below Numbers Bars
If you want to actually have the information above/below the bar, then you can use the Study Subgraph Above/Below Bar as Text. Note that there is not a way to get the numbers adjacent to each other (left to right), but you can use the above study twice and offset the numbers so they are stacked one above the other. Refer to the following:
