Date/Time: Tue, 26 Nov 2024 01:30:26 +0000
Wrong data in Trade Window
View Count: 1155
[2014-03-25 20:56:27]
User23271 - Posts: 13
When i log in platform from another computer, i see wrong data in Trade Window and DOM, how can i reload data?
[2014-03-25 21:13:50]
What specifically is wrong?
[2014-03-25 22:03:26]
displayed old position, which i closed from another computer
[2014-03-25 22:06:07]
Refer to this help topic:
https://www.sierrachart.com/index.php?l=doc/helpdetails80.html
Do see the correct position for the symbol displayed in Trade >> Trade Orders and Positions >> Positions?
Date Time Of Last Edit: 2014-03-25 22:06:39
[2014-03-26 14:07:48]
I see right information in Trade Orders and Positions, but wrong in Trade window and DOM
[2014-03-26 14:10:27]
Example: I opened buy from first computer and closed it from another computer, but after relog from first computer i see my position in Trade Window and DOM, but this position doesnt exist
[2014-03-26 16:39:34]
As explained in help topic 80, make sure you are not using the Order Fill Calculated Position:
Not quite sure this is related to the problem, however we recommend updating Sierra Chart to the latest version since you are using CTS T4, and using the new symbol format. This is explained here:
Notice: CTS Trading Service Symbols | Post: 27451
Date Time Of Last Edit: 2014-03-26 16:40:16
[2014-03-26 17:05:13]
After updating, i have position but i cant see it in Trade Window and DOM
Date Time Of Last Edit: 2014-03-26 17:11:11
[2014-03-26 17:10:35]
http://www.sierrachart.com/image.php?l=1395853819960.png
[2014-03-26 17:12:41]
Order Fill Calculated Position is disabled
[2014-03-26 17:51:24]
You need to change the symbol of the Trade DOM to the new format as explained here:
If you look at the symbol on the Positions tab on the Orders and Positions window, the symbol is different. That is the symbol you need to use.
Date Time Of Last Edit: 2014-03-26 17:51:59
