Date/Time: Sat, 01 Mar 2025 16:17:06 +0000
Keyboard shortcuts with AZERTY Keyboard
View Count: 445
[2021-09-23 13:28:45]
User893396 - Posts: 40
I am using an AZERTY (french) keyboard and I'd like to use the numerical keys (above the letters) as shortcuts.
The problem is that those keys produce numbers only when SHIFT is pressed, otherwise the following characters are produced:
& é " ' ( - è _ ç à
Most of these characters cannot be found in the keyboard shortcuts list.
Would you consider adding them so they become usable as shortcuts (for trading quantities, for tools configurations, etc...)
Thank you
[2021-09-23 15:11:14]
John - SC Support - Posts: 38292
We have set this as a Feature Request.
[2021-10-11 21:26:20]
Yes we will add these.
