Date/Time: Sat, 01 Mar 2025 05:22:05 +0000
2 question
View Count: 647
[2021-09-22 16:05:49]
User552931 - Posts: 25
Hi, how can I add the blue surround to the image? (volume profile in the graphic mass by days and the general volume profile.
And, where can I change the timing of the Japanese candles?
https://www.sierrachart.com/Download.php?Folder=TicketingSystem&download=54989
[2021-09-22 16:54:06]
John - SC Support - Posts: 38292
We are not sure exactly what you are looking for in this case, but refer to the following Input that for the Volume by Price that draws a rectangle around the profile:
Volume By Price Study: Draw Profile Outline Enclosing Bars
Again, we are not sure what you are specifically looking for.
You can change Session Times under Chart >> Chart Settings. Refer to the following:
Chart Settings: Intraday Session Times Start / End (Chart >> Chart Settings >> Session Times >> Intraday Chart Session Times menu)
Or if you are asking about the bar period, then that is also under the Chart Settings. Refer to the following:
https://www.sierrachart.com/index.php?page=doc/ChartSettings.html#TimePeriodPerBar
