Date/Time: Sat, 01 Mar 2025 06:58:01 +0000
Vertical Grid Increment
View Count: 596
[2021-09-22 13:10:19]
quin6 - Posts: 22
Hi, wishing you well.
I'm wanting to draw vertical grid lines with 742.5 increments.
Is there a way to do this?
Every time I try this, it doesn't allow for decimal places and rounds to 743.
Thanks! :)
[2021-09-22 13:44:33]
You mean the horizontal gridlines. Refer to:
Chart Menu: Horizontal Grid (Chart menu)
[2021-09-26 16:21:55]
quin6 - Posts: 22
Hi.
I wish to place decimals into the 'count' parameter in the 'vertical grid lines' box under the [Chart Settings >> Advance Settings 2] tab.
(See Picture Below).
*Example:* instead of 2025 as in the picture it could be 202.5.
I have already changed the increment of horizontal lines, I need to make the vertical line increments more granular.
Thanks.
Date Time Of Last Edit: 2021-09-26 16:23:26
imagevert grid.png / V - Attached On 2021-09-26 16:21:50 UTC - Size: 60.03 KB - 168 views
[2021-09-26 17:33:18]
John - SC Support - Posts: 38292
This has been set as a Feature Request.
[2021-09-27 14:17:37]
quin6 - Posts: 22
cool :) Thanks
