Date/Time: Fri, 02 Oct 2026 22:44:24 +0000
Overlapping issue
View Count: 1314
| [2021-09-22 05:20:59] |
| User272008 - Posts: 4 |
I am getting overlapping issue in DOM and it doesnt resolve even after changing the Market depth increment tick from chart advance setting. Image has been attached.
| [2021-09-22 13:49:18] |
You really need to expand the values on the scale to avoid this. Refer to: The Chart DOM Scale Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2021-09-22 14:00:36] |
Scaling/expanding Doesnt resolve this issue. See image.
| [2021-09-22 15:14:24] |
| John - SC Support - Posts: 48095 |
Are you using a different Tick Size than what is being sent by the exchange? If so, then this would explain what you are seeing. In which case, you may want to combine the Market Depth so that it lines up with the Tick Size you have selected. Refer to the following: Chart Settings: Market Depth Combine Increment in Ticks (Chart >> Chart Settings >> Market Depth menu) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2021-09-22 15:40:17] |
Yes, using different tick size. And also tried "MarketDepthCombineIncrementInTicks" setting. It only resolve the overlapping of Ask/Bid size in Dom. It does not solve the overlapping issues of other columns such as current Bid/Ask pulling/Stacking, Current Total Volume and other other columns. Watch the above sent images again for more clarification.
Date Time Of Last Edit: 2021-09-22 15:41:23
| [2021-09-22 15:55:32] |
We are aware that the Market Depth Combine Increments in Ticks is only valid for the Bid and Ask and there is a desire to have it for other columns as well. We have several Feature Requests for this.
