Date/Time: Sat, 13 Sep 2025 05:12:31 +0000
Heatmap automatically change highest quantity
View Count: 772
[2021-09-21 20:33:32]
User674409 - Posts: 26
Hello, I use Sierra chart heatmap. Im wondering if there is anyway to setup my heatmap, so the studies determine automatically the highest quantity, for the first 40 levels, so I dont have to change that value anytime the market liquidity change. Let´s say that in determinate moment the liquidity in the SP500 gives my 400 contracts as the highest quantity. But 30 mins later the liquidity changes and the highest liquidity now is 230 contracts....I need to change that value manually in my heatmap (Market depth historical graph) to 230.....What I want is that Sierra chart determine that automatically. Is that possible? That, the studies notice that change in the liquidity and change it by itself.
[2021-09-22 09:46:45]
User438057 - Posts: 51
Use Percent instead of Actual in the setting: Use Percent or Actual Values for Threshold Levels
[2021-09-22 14:50:17]
John - SC Support - Posts: 41793
As stated above, the only option is to use the Percent Color Thresholds. Refer to the following:
Market Depth Historical Graph: Use Percent or Actual Values for Threshold Levels
