Date/Time: Sat, 01 Mar 2025 16:20:49 +0000
IN chart settings - Price Display Format - Does AUTO-SET FROM DATA FEED change format ?
View Count: 13155
[2021-09-21 16:40:29] |
GravisHTG - Posts: 306 |
Does it"s suppose to change the format automaticly or not? I did some researh on your website and tried this Price Display format and Tick Size but it did not change anything. Would Love to know Because in STOCK trading , LOW Penny stock are keeping the 0.01 format instead of going for the 0.0001 format. And its on all penny stock that require 0.0001 format. ( just look at the OTC symbols ) 1 example : TICKER - FAMI So ,I keep it very simple for you guys, Because I really dont want and dont like, to waste your time and my time. If you can Just give me an answer from A - B or C , that is all I need. A - Yes, its suppose to change the Price Display format and the TICK SIZE automaticly and its something wrong on my side B - Yes, its suppose to change the Price Display format and the TICK SIZE automaticly, but their is something wrong on your side that need to be fix and will be fix when you have time. C- No, its not suppose to change the Price Display format and the TICK SIZE automaticly, you just dont understand what it does. Thanks in advance And I told you guys , I really like your program. My mind just need to know and understand stuff sometimes. Date Time Of Last Edit: 2021-09-23 12:19:09
[2021-09-22 22:09:54] |
So , Is it A - B or C ? thanks in advance. |
[2021-09-25 13:04:23] |
I keep it simple , I just want to know A - B or C - No need for all your link or other elaborate answer. thanks Date Time Of Last Edit: 2021-09-25 17:56:43
[2021-09-30 12:58:43] |
A - B or C ?
[2021-10-11 23:31:48] |
That setting will not necessarily change the format. It depends upon what security definition data is available for the symbol from the data feed. We really would have to research this.
