Date/Time: Sat, 01 Mar 2025 05:11:52 +0000
Alert condition referring to a manually drawn line
View Count: 694
[2021-09-21 08:56:04] |
User238799 - Posts: 15 |
I would like to define a simple Alert condition (just based on IF, AND, OR), but referring to a 'Line' which is drawn manually by the drawing tool 'Line'. For defining this Alert condition, I need to refer to the ID and the SG of this manually drawn Line. 1. Best would be: If there would be a solution, to refer directly to a Line manually drawn by the Line drawing tool. (how zo do that? As far as i know, a manually drawn line does not have an ID and a SG) 2. Alternative solution: If '1.' is not possible, I would like to use the 'Line' Studie and Enter manually the level needed in the In:4 of the studie. But for entering and changeing the level needed in In:4, the best would be to have a Field directly on the screen which is Linked to the specific Subgraph and In:4 for entering it fast and easy. Is there a slolution to solve my issue? Thanks very much ! |
[2021-09-21 16:08:40] |
John - SC Support - Posts: 38292 |
Refer to the following: Study/Chart Alerts And Scanning: Referencing Chart Drawings For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
