Date/Time: Wed, 12 Mar 2025 04:37:42 +0000
Support query: Will my DLL keep working after the upcoming softw
View Count: 1874
[2013-04-23 13:31:19] |
PhilipJames - Posts: 34 |
A while back I paid your recommended programmer to write me a simple indicator for Sierra (a DLL I think) It appears to still work perfectly with the current version (967) Will it keep working once you have made all the planned changes to the software that are in the pipeline? Thanks. |
[2013-04-23 13:57:40] |
Yes, but if a recompile is required, then that is easy enough to do as long as you have the source code. However, there is no plan from us to be requiring a recompile.
