Date/Time: Sat, 01 Mar 2025 05:37:05 +0000
AMP Account Activation
View Count: 572
[2021-09-21 05:04:53] |
User818919 - Posts: 1 |
Can you please activate my AMP account. What do I need to do next to begin using Sierra charts for simulated trading? I need someone to assist me with importing Sierra chartbooks from TradePro, please let me know the next steps to take. Thank you. Patti |
[2021-09-21 14:32:39] |
John - SC Support - Posts: 38292 |
There are a set of instructions to get your Sierra Chart connected to your AMP account. But it depends on what Order Routing service you have been setup to use with AMP. If you are setup with CQG, then follow these instructions: CQG Trading Platform Service: Setup Instructions If you are setup with Rithmic, then follow these instructions: Rithmic Trading Platform Service: Setup Instructions --------------- In terms of a chartbook that you have received from elsewhere, refer to the following instructions: Chartbooks (Workspaces): Using a Chartbook Provided by Sierra Chart Support For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2021-09-21 14:33:50
