Date/Time: Sat, 01 Mar 2025 05:33:09 +0000
Copying Chart Drawings Issue
View Count: 419
[2021-09-20 21:59:35] |
user8888 - Posts: 159 |
At least in those releases appears to me that a simple "copy chart drawings from chart#" has stopped working properly. Thanks |
[2021-09-21 00:29:14] |
John - SC Support - Posts: 38292 |
We just did a simple test and that test is working fine. Is there a particular situation that you can define in which this is occurring?
[2021-09-21 10:19:47] |
Refer to: Chart Settings: What to Do If Chart Drawings Do Not Copy Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
