Date/Time: Sat, 01 Mar 2025 05:21:46 +0000
Changing the scale in Sierra Charts
View Count: 730
[2021-09-20 18:43:20]
Ben A - Posts: 123
I was wondering if there was a way to change the price scale on Sierra Charts to match the scale of another instrument.
For example. If difference (spread) between SPY and ES is approximately 10.013 - Being able to use the SPY price scale x 10.013 to make it equivalent to ES.
And then after this is done overlaying the SPY pricing upon ES chart?
Thanks for your help, I hope I explained this OK!
Best Wishes,
[2021-09-21 00:17:13]
John - SC Support - Posts: 38292
First, you can always overlay one chart on another and set the overlay to a scale of Independent, which will allow you to see both at the same time, and you can use the left-side scale to see the scaling for the second instrument. If you are going to do this, the best way is to use the Add Additional Symbol study and set the scale to Independent for that study. Refer to the following for the Add Additional Symbol:
And refer to the following regarding Independent scaling:
Chart Scale and Scale Adjusting: Independent (Scale Range)
And refer to the following for the Left-Side scale:
Chart Settings: Use Left Side Scale (Chart >> Chart Settings >> Scale menu)
Now that being said, if you still just want to adjust the values of one instrument to match up to another, then you would still use the Add Additional Symbol to add the desired symbol to the chart, but keep this study hidden. Then use the Spreadsheet Formula (Bar) to do the multiplication where you reference the Open/High/Low/Close from the Add Additional Symbol subgraphs into the equations for the Spreadsheet Formula (i.e. you would have something like "=ID1.SG1 * 10.013" for the Open formula where ID1 is the ID of the Add Additional Symbol and SG1 is the first Subgraph (Open).
Refer to the following for the Spreadsheet Formula (Bar) study (it's the same information as Spreadsheet Formula except that you enter the 4 parameters to create the bar):
Spreadsheet Formula
Date Time Of Last Edit: 2021-09-21 00:17:31
[2021-09-21 02:50:28]
Ben A - Posts: 123
Awesome John, super clear and gives me everything I need. Thank you!
