Date/Time: Sat, 01 Mar 2025 05:11:27 +0000
studies not visible
View Count: 482
[2021-09-20 18:16:08] |
User475342 - Posts: 8 |
After the rollover period some of my studies are not visible. Several composite volume profiles and a VWAP study are not visible on my charts. Can you help please?
[2021-09-20 23:54:56] |
John - SC Support - Posts: 38292 |
The first question is whether the studies are on the chart still or if they were removed for some reason. Once you have the particular chart active, select Analysis >> Studies in order to see the list of studies that are on that particular chart. If they are still listed, but are not displaying, then you would need to look at the reasons why that would occur. For example, do you have enough days of data loaded (are there enough days of data in the new contract) for what you have defined in the studies (and keep in mind if you want the chart to be a Continuous Contract or not). There could be any number of other reasons. Again, you will have to take a look and see how the studies are set and whether you have the information you need in the chart. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2021-09-21 08:57:55] |
Still listed in Analysis, days of data more than enough, new contract started Friday 17/9, chart setting Automatically Rollover Futures Symbol enabled, Hide All Studies not enabled. This is regarding the composite profiles. The VWAP study has reappeared today. |
[2021-09-21 15:25:09] |
Refer to the section here regarding this: Chart Studies: Resolving Study Not Visible Issue Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
