Date/Time: Sat, 01 Mar 2025 05:12:09 +0000
duplicate all charts to a new chart book
View Count: 1911
[2021-09-20 16:39:15]
User161894 - Posts: 13
I am trying to duplicate a chart book into a new chart book. When Duplicate all charts to another Chartbook window opens, it does not see the new chartbook1. I can not find the destination (ChartBook1) to have all the chart duplicate in there.
could you please help?. I tried to do that by on chart by one chart and still not getting anywhere. I am attaching a copy of the pop window in here.
Thank you,
Ash
imagechart duplicate.PNG / V - Attached On 2021-09-20 16:35:11 UTC - Size: 83.04 KB - 301 views
[2021-09-20 17:33:49]
John - SC Support - Posts: 38292
The Chartbook that you want to duplicate to needs to be open.
But, it also could be just that you need to understand how to use those new windows. Refer to the information at the following link for how to use that particular window item to select the chartbook:
Settings Windows Interface: Item List (Working with Sierra Chart Windows >> Selection Specific Options)
[2021-09-20 22:19:58]
The Chaartbook that I want to duplicate to is open however, if you check out the attachment you will see that it does not have it. for some reason it can not see chartbook!
[2021-09-20 22:30:34]
Hi there,
just want to follow up on my last respond to your e-mail. I took a screen shot to show you how many chart book I have open. if I go duplicates a chart this is the window I get to open up. there is list to pick from even though i have many of them open up. See attachment
imagehow to duplicate a chart.PNG / V - Attached On 2021-09-20 22:30:26 UTC - Size: 51.29 KB - 257 views
[2021-09-21 00:37:49]
You have to select the list item to open it up and see the list. In other words, you need to click where you see "Ash Chart ES.cht". When you do so, you will get the list of chartbooks to select from. Refer to the information on how to work with that particular window item here:
