Date/Time: Sat, 01 Mar 2025 04:59:51 +0000
Correct data
View Count: 368
[2021-09-20 16:33:35]
JesseW - Posts: 6
Do I have the correct data plans setup? I just want live futures with TPO & equities with TPO.
imageScreenshot 2021-09-20 093131.png / V - Attached On 2021-09-20 16:32:18 UTC - Size: 50.83 KB - 130 views
[2021-09-20 17:32:12]
John - SC Support - Posts: 38292
As long as you are just looking for the CME Group for futures, then you are all set.
You have the Denali Exchange Data Feed with the Full CME Group exchange active, and you have the Sierra Chart Exchange Data Feed with the U.S. Equities exchange. In addition, you are on Package 11, which gives you the Advanced features, which includes the TPO profiles.
