Date/Time: Sat, 01 Mar 2025 14:23:32 +0000
Trade account not assigned
View Count: 903
[2021-09-20 16:09:58]
User223281 - Posts: 58
Hello I am trying to sign in to use the SC order routing data feed. It has been a while since i signed in and used the service, and i am getting a trade account not assigned message. Im not sure how to proceed
[2021-09-20 17:27:53]
John - SC Support - Posts: 38292
Who is your broker?
[2021-09-20 18:14:52]
Amp Futures
[2021-09-20 23:47:00]
It must have been since February since you have been into the software.
Back in February, there was an issue with TT and the CME Group for a few days. In light of this, AMP decided to stop support for the Sierra Chart Order Routing Service. At that time, they were supposed to move all their customers that were using that service to use CQG for their order routing instead.
As such, you should have received information regarding a CQG account an login information from AMP. If you do not have these, then you need to talk with AMP about getting setup with CQG.
If you do have the information, or when you do get it from AMP, then follow the instructions at the following link to setup your Sierra Chart to connect to your CQG account:
CQG Trading Platform Service: Setup Instructions
If you are wanting to continue to use the Sierra Chart Order Routing Service, then you would need to change brokers. A partial list of brokers/FCMs can be found in Step #2 at this link:
https://www.sierrachart.com/index.php?page=doc/SierraChartOrderRoutingServiceWithData.php#SetupInstructions
Also, be aware that we are working on a new Direct to CME order routing service that we hope will be available in October. For more information on this service, refer to the following Support Board thread:
Now Released: Upcoming CME Direct Routing
[2021-09-23 16:41:54]
Is there a way I can just use SC data instead?
[2021-09-23 17:04:45]
We are not understanding your question. You are currently setup to use the Sierra Chart data - you have the CME with Market Depth exchange active on the Denali Exchange Data Feed.
[2021-09-23 23:18:01]
i am getting delayed data when connected to SC Data - All Services
[2021-09-24 17:54:03]
This is because you have not connected to your live trading account in order to verify that you have the account for the CME Group non-professional exchanges. This is why you need to make the connection using either CQG or Rithmic, depending on how AMP set up your account.
Refer to the following for more information:
Real-Time Exchange Data Feeds Available From Sierra Chart: Understanding and Accessing Data From the CME, CBOT, NYMEX, COMEX Exchanges
[2021-10-06 14:31:59]
I have enabled CQG through AMP. I now need login information or connection to Sierrachart. How can I setup the connection in Sierrachart?
[2021-10-06 14:53:31]
Follow the instructions here for CQG:
[2021-10-06 15:44:26]
ok I have set it up and am connected with live data. However, when i put in an order to trade, it only stays for a second and then disappears. How can I get the orders to go through?
[2021-10-06 17:40:59]
Our servers are showing that your Current Selected Service is SC Data - All Services. In other words, you are not connected to your CQG account.
Follow these instructions to get connected to your CQG account:
[2021-10-06 17:57:43]
Yes i have followed these instructions, and am connected to CQG and recieving live data. But my orders arent going through. IS there something different i need to do to get the orders to go through?
[2021-10-06 18:31:53]
Please go to Global Settings >> Data/Trade Service Settings and tell us what is entered in the field next to Current Selected Service.
[2021-10-06 18:34:59]
CQG WebAPI [trading]
imageScreen Shot 2021-10-06 at 12.33.48 PM.png / V - Attached On 2021-10-06 18:34:34 UTC - Size: 14.61 KB - 146 views
[2021-10-06 23:46:47]
For some reason your system is not updating to our servers, so we think there may be something odd occurring with your setup.
We need for you to exit from Sierra Chart and then log back into the software using the Forced Login option. Refer to the following information for how to do this:
Sierra Chart - Software Login Instructions: Forced Login
After you do the above, try to place a trade and let us know if things are working properly or not.
