Date/Time: Sat, 01 Mar 2025 05:36:55 +0000
Rectangle Drawing Tool
View Count: 1647
[2021-09-20 14:41:26] |
countryboy92 - Posts: 91 |
When I draw a rectangle in a tick chart, the rectangle is expanding by itself to the right after a certain amount of time goes by. How do I keep the rectangle staying in place and remaining fixed in place on the time x-axis.
[2021-09-20 16:53:23] |
John - SC Support - Posts: 38292 |
There are two different types of Rectangle drawings - Rectangle and Extending Rectangle. It sounds like you are using the Extended Rectangle when you want to just use the Rectangle. Also refer to the information here on these two items: Chart Drawing Tools: Rectangle | Extending Rectangle | Ellipse | Triangle For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
