Date/Time: Sun, 04 Oct 2026 23:48:32 +0000
tools
View Count: 797
| [2021-09-20 14:22:47] |
| User318521 - Posts: 52 |
Do you have or can you make a tool that work like the price expansion tool but instead of expanding at a percentage it will create lines at a certain tick. for example, I have been creating two lines for support and resistance, then taking the gann grid and lining the two points up with those two lines, I then draw multiple lines lining up what the grid horizontally to create evenly spaced support and resistance lines. I'm looking for a tool to make this process easier. is a way where I could find two good lines for support and resistance and the spacing between those two lines be the same between a multiple of lines that automatically appear. think of it like this. the gann grid makes diamonds boxes that are equal from the top and bottom depending on how much you expand and contract them. That's perfect. I then take the horizontal lines tool and draw line on the top and bottom of the diamond to make multiple lines evenly spaced. Im trying to make this process easier and find a tool that will do this, kind of like the price retracement tool. but the retracement tool works off of percentages unlike the gann grid that works off of equal expansion. I hope I explained this good enough thanks jory |
| [2021-09-20 16:33:28] |
| John - SC Support - Posts: 48095 |
We understand what you are looking for, but unfortunately we do not have a tool that can do this. It does not sounds like this would be hard to program for a custom study, so you may want to look into that route. If you are interested in coding yourself, then refer to the following: Advanced Custom Study Interface and Language (ACSIL): Introduction If you want to look for someone that could code this for you, refer to the following: List of Third Party Sierra Chart Study and System Programmers For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
