Date/Time: Sat, 01 Mar 2025 05:24:54 +0000
Global profit / loss management
View Count: 454
[2021-09-19 20:12:13]
User540050 - Posts: 7
I am having an issue with the Daily net loss management feature. I am trading MESZ21 on EPZ21 charts using the trade only check box on the chart. I have checked off the Flattten positions when loss rule met, and have the loss trigger value set to -20.00. It worked fine before but I did install an updated version now I am on version 2308. now, I am getting flattened and locked out after 2 ticks against me on a single MES. I believe I have it set for 16 ticks of loss. It would seem as though the setting for daily net loss management is looking at EPZ21 and seeing a $25 loss thus flattening me? Do I have a setting that is now changed from downloading the update that I need to revert back?
thanks
[2021-09-20 14:43:38]
John - SC Support - Posts: 38292
There should not be a change due to the update. It sounds like your Currency Value per Tick is set for the EPZ21 and not for MESZ21. When you are using the Trade and Current Quote Symbol, if you want your P/L to reflect the traded security, then you need to ensure that the Currency Value per Tick is set for the Trade and Current Quote Symbol. Refer to the following information:
Chart Settings: Updating Currency Value per Tick for Trade Symbol
