Date/Time: Thu, 06 Mar 2025 09:55:45 +0000
IB Trading Service + Denali Exchange Data Feed sometimes slow in Germany
View Count: 1018
[2021-09-19 18:23:35]
User542502 - Posts: 16
I tried the Denali Exchange Data Feed two weeks ago. Sometimes the CME market data was "slow" during fast market moving activity. It looked like some latency/jitter problem between my location in Germany and the Denali market data server in the US. I was connected with s21.sierracharts.com. So I suppose it's located near by the Aurora data center?
I was using the Denali feed in conjunction with the Interactive Brokers trading service. The CME data feed provided by IB (TWS) wasn't slow at all during the same time.
Is it possible to use a Denali market data relay located in Germany or London? I would really like to use the Denali feed, but the market data feed should come from a Denali relay server located in Europe. Thanks :)
[2021-09-20 14:45:21]
Sierra_Chart Engineering - Posts: 18669
Refer to this section:
Prices / Data Falling Behind: 4.12 - Sierra Chart Exchange Data Feeds
There is a server in London, for the Denali Data Feed. It is not automatically used but is one of the available choices. You can reconnect to the data feed, and when you see a connection to ds6-2.sierracharts.com that is the London server.
Date Time Of Last Edit: 2021-09-20 14:46:14
[2021-09-20 16:32:47]
"It is not automatically used but is one of the available choices. You can reconnect to the data feed...". Okay, but how can I do this?
I'm using the IB Trading Service in Sierra Chart 2310. The only option I can find is to set "Common Settings -> "Allow Support for Sierra Chart Data Feeds" = "Yes".
[2021-09-20 18:59:57]
You just need to reconnect until Sierra Chart reconnects to that server. Instructions:
[2021-09-20 20:20:04]
No, it does never connect to ds6-2.sierracharts.com.
The log is telling me:
Software version: 2310 64-bit | 2021-09-20 22:09:45.956
OpenGL enabled (NVIDIA Corporation/Quadro P400/PCIe/SSE2) | 2021-09-20 22:09:45.966
Primary Thread ID: 4928 | 2021-09-20 22:09:45.966
Usage end date: 2021-10-06 | 2021-09-20 22:09:45.966
Enabled for: Sierra Chart Historical Data Service. | 2021-09-20 22:09:45.966
Enabled for: Denali Real-Time Exchange Data Feed. | 2021-09-20 22:09:45.966
Enabled for: Delayed Denali Exchange Data Feed. | 2021-09-20 22:09:45.966
Enabled for exchange2: CME (Trading Account Required) | 2021-09-20 22:09:45.966
Enabled for exchange2: CBOT (Trading Account Required) | 2021-09-20 22:09:45.966
Enabled for exchange2: COMEX (Trading Account Required) | 2021-09-20 22:09:45.966
Enabled for exchange2: NYMEX (Trading Account Required) | 2021-09-20 22:09:45.966
Allow Support for Sierra Chart Data Feeds is enabled. | 2021-09-20 22:09:45.966
Current selected Data/Trading service: Interactive Brokers | 2021-09-20 22:09:45.966
Custom symbol settings values: enabled | 2021-09-20 22:09:45.966
Chart Update Interval: 10 | 2021-09-20 22:09:45.966
Intraday Data Storage Time Unit: 0 | 2021-09-20 22:09:45.966
Time Zone: +02:00:00 (CET+01CEST+01,M3.5.0/02:00,M10.5.0/03:00) | 2021-09-20 22:09:45.966
2021-09-20 20:09:45 Local computer time in UTC | 2021-09-20 22:09:45.966
2021-09-20 22:09:45 Local computer time in SC Time Zone | 2021-09-20 22:09:45.966
2021-09-20 17:17:43 Server time in UTC | 2021-09-20 22:09:45.966
Local computer UTC time and Server UTC time difference: 0 seconds. | 2021-09-20 22:09:45.966
SC Data - All Services | Starting real-time market data updates for: CL-202111-NYMEX (CLX21). ID: 1 Service code: nymex | 2021-09-20 22:09:54.986
SC Data - All Services | Connecting to the server ds22.sierracharts.com. Port 443 | 2021-09-20 22:09:54.986
HD Request # 33 | Downloading Intraday chart data for MNQ-202112-GLOBEX-USD to the file MNQ-202112-GLOBEX-USD.scid. Service: cme | 2021-09-20 22:10:02.744
HD Request # 33 | Download start date-time: 2021-09-20 22:09:23.000000. File last date-time: 2021-09-20 22:09:23.823002 | 2021-09-20 22:10:02.745
HD Request # 33 | Using server: ds21.sierracharts.com port 10149 | 2021-09-20 22:10:02.745
Why?
[2021-09-21 15:32:48]
Let us think about what we can do for you. Are you connecting from Germany?
[2021-09-21 16:13:07]
Yes, I'm connecting always from Germany. I would really appreciate a solid solution. Btw, the Interactive Brokers TWS app gives me an option to select my region (Europe). May be Sierra Chart could add a similar feature.
[2021-10-08 00:05:55]
We apologize for the delay. We have set your account to use the London server first.
Restart Sierra Chart.
[2022-01-27 18:36:39]
User391959 - Posts: 17
Hi
I use IB Trading Service + Denali Exchange Data Feed out of Europe.
I face heavy performance issues (SC freezes in fast trading hours) when being connected to IB as compared to be directly connected to SC Data All.
I only use IB as an execution broker, Data should all come from my SC Denali.
Anything I can do?
Did the Denaly Server change help in the above case?
[2022-01-27 20:59:01]
UserOne - Posts: 40
Could you set my account to use the London server first, too? I am connecting to ds23 right now.
Date Time Of Last Edit: 2022-01-28 15:20:45
[2022-01-28 07:16:20]
I would like to add:
I see [M] behind the symbols
Is this correct and what does it indicate?
I want to use only SC Denali Data Feed and use IBKR only as execution broker for trading.
[2022-01-31 06:23:54]
Refer to help topic 30:
High CPU Usage | Inactive User Interface | Poor Performance | Long Time to Load Chart Data | Charts Reloading Often
Regarding this, refer to:
Real-Time Exchange Data Feeds Available From Sierra Chart: Integration with Trading Services
This is now done for your account:
Date Time Of Last Edit: 2022-01-31 06:26:26
