Date/Time: Sat, 01 Mar 2025 04:13:49 +0000
Sierrachart upgrade 2270 to 2308 to Avoid Bad effect on RSI-W Study? What's the procedure?
View Count: 480
[2021-09-18 02:46:28] |
User14953 - Posts: 243 |
What's the procedure for Sierrachart upgrade 2270 to 2308 to Avoid the Bad effect on RSI-W Study?
[2021-09-18 10:46:32] |
Sierra_Chart Engineering - Posts: 18607 |
Refer to the release notes here for version 2310 for instructions: https://www.sierrachart.com/index.php?page=doc/Whats_New.php#SCVer2310 To update to 2310, refer to: Software Download: Fast Update Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
