Date/Time: Sat, 01 Mar 2025 04:14:07 +0000
Sending Orders in different instances
View Count: 417
[2021-09-17 22:44:25]
User143517 - Posts: 68
Hi there,
Could you guide me through the process of simultaneously sending orders from two different instances of SC(not sub instances), being one in live mode and the second instance in sim mode?(If possible).
Best Regards,
[2021-09-18 10:47:27]
Sierra_Chart Engineering - Posts: 18607
This is not supported.
[2021-09-19 15:44:12]
Ok. Thank you. Could I do that using a sub instance then? I mean, send a live order from an instance that will simultaneously send a Sim order on a sub instance?
[2021-09-19 16:32:39]
John - SC Support - Posts: 38292
No, that will not do it either. It is simply not supported to do what you are wanting.
