Date/Time: Sat, 01 Mar 2025 03:50:51 +0000
Missing TPO Data with Continuous Contracts
View Count: 485
[2021-09-17 19:47:49]
IANX - Posts: 3
Problem: TPO data missing for date range 8/6/2021 - 9/13/2021 (see "sierra support" image)
Steps Taken:
1. Tried various Continuous Contract options. The dates are only visible when the selection is set to "None"
2. Deleted and downloaded data from beginning chart period (3/2/2021)
3. Created a new TPO chart
4. Performed Symbol Settings "Update From Server"
Thank you for the help.
Date Time Of Last Edit: 2021-09-17 20:13:46
imagesierra none.JPG / V - Attached On 2021-09-17 19:46:31 UTC - Size: 331.21 KB - 171 views
imagesierra continuous.JPG / V - Attached On 2021-09-17 19:46:37 UTC - Size: 89.1 KB - 145 views
imagesierra support.JPG / V - Attached On 2021-09-17 19:46:46 UTC - Size: 251.83 KB - 159 views
[2021-09-18 11:58:23]
Follow through the instructions here:
Re-download the data, for the last two contract months and be sure to disable the use of Custom Symbol Settings values.
Date Time Of Last Edit: 2021-09-18 11:59:33
