Date/Time: Sat, 01 Mar 2025 04:20:43 +0000
change background color test display
View Count: 581
[2021-09-17 17:13:57]
User993067 - Posts: 167
using the test display study from chart indicator....
can i change the background color based on the imported value?....sound alert also does not seem to work here
[2021-09-17 17:14:46]
attached photo
imageCapture4.PNG / V - Attached On 2021-09-17 17:14:24 UTC - Size: 217.27 KB - 160 views
[2021-09-17 17:33:12]
John - SC Support - Posts: 38292
To change the background based on the Input you would have to change the code for the study. You can find the code in the studies3.cpp file located in the ACS_Source folder under the main Sierra Chart installation folder.
Refer to the following for how to create the study after you have modified it:
How to Build an Advanced Custom Study from Source Code
