Date/Time: Tue, 15 Sep 2026 06:00:20 +0000
15 min historical data
View Count: 1123
| [2021-09-17 16:21:36] |
| User720813 - Posts: 11 |
Is there a way to use historical data for anything higher than 15 min time frame? Currently from what i can tell all historical data is on a 24 hour time frame and higher.
| [2021-09-17 16:30:23] |
We are not understanding the question. You can set the chart bars to any timeframe that you require: Changing Chart Bars Period In the case of an Intraday chart, to load more data in the chart, refer to: Historical Intraday Data (Missing Data / Download Errors / Viewing More Data): Downloading/Viewing More Historical Intraday Data Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2021-09-19 19:59:51] |
Hello thank you for your quick response. The issue that im having is that for intraday data, on a majority of stocks, not all, im only getting around 7-10 days worth of data. I have went through the links above thoroughly and its still not solving the issue. For example.... ticker TMC, i can only see 7 days worth of intraday data. However ticker IPHA i can see all the way back to early June.
| [2021-09-20 01:33:51] |
We do only see data for TMC back to 2021-09-10. This is all that is available. It must be a new symbol. What is another symbol you have an issue with? Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2021-09-20 01:34:17
