Date/Time: Sat, 01 Mar 2025 03:56:56 +0000
[Programming Help] - Create a New Custom Study
View Count: 723
[2021-09-17 12:50:58]
SierraTraders - Posts: 69
Hello, Can anyone look at this study and help with this issue please
The remote build did not succeed. Result:
In file included from sierrachart.h:22,
from UTP_Pro.V4.cpp:1:
UTP_Pro.V4.cpp: In function 'void scsf_ProfitLossTextStudy(SCStudyInterfaceRef)':
scstructures.h:117:28: error: expected unqualified-id before string constant
117 | #define SCDLLEXPORT extern "C" __declspec(dllexport)
scstructures.h:117:28: note: in definition of macro 'SCDLLEXPORT'
UTP_Pro.V4.cpp:18:1: note: in expansion of macro 'SCSFExport'
18 | SCSFExport scsf_ProfitLossTextStudy(SCStudyInterfaceRef sc)
UTP_Pro.V4.cpp:26:49: error: expected ']' before ';' token
26 | SCInputRef Input_ShowClosedPL = sc.Input[7;
UTP_Pro.V4.cpp:51:3: error: 'Input_HorizontalPosition' was not declared in this scope; did you mean 'Input_VerticalPosition'?
51 | Input_HorizontalPosition.Name.Format("Horizontal Position From Left (1-%d)", (int)CHART_DRAWING_MAX_HORIZONTAL_AXIS_RELATIVE_POSITION);
attachmentUTP_Pro.V4.cpp - Attached On 2021-09-17 12:48:06 UTC - Size: 4.81 KB - 280 views
[2021-09-17 13:00:33]
User907968 - Posts: 833
Attached with edits
attachmentUTP_Pro.V4.cpp - Attached On 2021-09-17 13:00:17 UTC - Size: 4.85 KB - 375 views
[2021-09-17 14:20:56]
Thanks for the help it has compiled and is in input list for study....... but no text on chart
As these where added to calculate the account balance
SCInputRef Input_ShowCurrentAccountBalance = sc.Input[21]; (this would be the total of IN:8 and IN:21)
SCInputRef Input_ShowStartingAccountBalance = sc.Input[22]; (This would need to type in a start balance amount)
[2021-09-17 15:41:12]
The attached code only contained the 'sc.SetDefaults' section, assumed you'd deleted the main study code for privacy reasons.
So unless you have added anything in, it will not do anything other than configure the inputs (as you've noticed).
Also, the 'return', is missing at the end of 'sc.SetDefaults'.
if sc.SetDefaults
/// do stuff
return;
[2021-09-19 10:36:30]
Attached is the source code for the SC Study "Trading Profit/Loss Text"
attachmentUTP_Pro.V5-2-Test.cpp - Attached On 2021-09-19 10:31:59 UTC - Size: 10.43 KB - 389 views
