Date/Time: Sat, 01 Mar 2025 05:40:44 +0000
^XAUUSD-MSFOREX
View Count: 1246
[2021-09-17 10:40:20] |
User797053 - Posts: 7 |
Is it possible to get ^XAUUSD-MSFOREX live data ?
[2021-09-17 11:16:21] |
You can but it would not make any sense. Instead you can use the CFD symbol XAUUSD that Sierra Chart has. These are in File >> Find Symbol >>CFD-FXCM. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2021-09-17 11:22:08] |
Thank you for your reply. How do I get it live please ? |
[2021-09-17 11:32:30] |
You should be receiving real-time data for XAUUSD now. Are you not?
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2021-09-17 11:32:42
[2021-09-17 11:39:06] |
Yes I am, but the chart I need live only updates every 10 minutes.
[2021-09-17 11:43:45] |
So you are saying the symbol XAUUSD is only updating every 10 minutes? Check the Chart Update Interval: Chart Settings: Chart Update Interval in Milliseconds (Chart >> Chart Settings >> Display >> Chart Update Interval menu) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2021-09-17 11:45:54] |
Yes that is correct.
[2021-09-17 13:06:35] |
That symbol should be updating continuously. Often every second. Follow the instructions here to update the Symbol Settings: Global Symbol Settings: Update Global Symbol Settings Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2021-09-17 13:06:48
[2021-09-20 06:20:07] |
Would remote assistance be possible please?
