Date/Time: Wed, 12 Mar 2025 04:43:42 +0000
Trading from sierra
View Count: 2119
[2013-04-23 13:23:25]
roman06 - Posts: 9
Hi, can I somehow trade straight from sierrachart? My broker is mirusfutures. Thanks for reply. Roman
[2013-04-23 14:03:12]
Yes, for sure.
To use your Mirus account, please follow through the instructions here:
http://www.sierrachart.com/index.php?l=doc/ZenFire.php
Make sure that you update to the current version by selecting Help >> Download Current Version.
For trading instructions, follow the instructions here:
http://www.sierrachart.com/index.php?l=doc/doc_Trading.html
[2013-04-23 14:30:50]
roman06 - Posts: 9
I have problem with disabling the simulation mode. It writes me that its not possible to turn it off when chart replying, but I am not in replay mode. Thank you
[2013-04-23 14:53:13]
You must have one chart replaying which you are not aware of. If you are not sure which chart it is, restart Sierra Chart.
