Date/Time: Sat, 01 Mar 2025 04:39:45 +0000
What are the conditions for the advanced features of Service package 11?
View Count: 669
[2021-09-16 10:53:49]
Пользователь488020 - Posts: 100
I want to run service package 11 but cannot understand the explanation of the terms of this service package 11. When I follow the link on Description of Service Packages and Pricing: Base Sierra Chart with Advanced Features (Service Package 5) I don't see the conditions for advanced features. Please give a link to the description of the advanced features of the package 11. What is the difference between Service Package 11 and 10? And 11 from 12?
Date Time Of Last Edit: 2021-09-16 10:57:49
[2021-09-16 15:42:08]
John - SC Support - Posts: 38292
The descriptions of the packages can be found here:
Description of Service Packages and Pricing: Packages
[2021-09-16 20:45:28]
I want to connect package 12. I have an AMP broker, I have set up a connection to Denali.
I have a 1 question.
I will trade any contracts that are listed on the Available Symbols in Sierra Chart or those listed on the AMP website (limited number contract).
The question is also.
How the commission for transactions will be carried out. Give links.
[2021-09-16 23:20:01]
We do not know the answer to this. If AMP has a limited number of instruments that they say you can trade, then we would think that you would be limited by them. You need to ask AMP about this.
Commissions are handled by your broker. Again, you need to ask AMP about this.
[2021-09-18 20:00:02]
hello! My broker AMP. I am using the Sierra Chart - Denali - SQG connection. In the message of the Sierra Chart Does Not Recommend CQG (Various Reasons) | Post: 272724 indicated the movement of users from SQG in September 2021, once the direct order routing service is out for CME and EUREX.
My question is what instructions will be for such a transition and when to wait for this event?
Date Time Of Last Edit: 2021-09-18 20:02:14
[2021-09-19 15:46:29]
The information for the Direct CME/EUREX Order Routing can be found at the following link and will have information to instructions when the time comes:
Now Released: Upcoming CME Direct Routing
