Date/Time: Sat, 01 Mar 2025 01:54:49 +0000
DPL records opposite of actual trades.
View Count: 544
[2021-09-15 17:40:48] |
User964846 - Posts: 38 |
My DPL is WAAY off from what it should be. I am using Sierra Data and Order Routing. & my actual wins and losses for the day based on my account balance, are WAAAY off from where they should be today. When I go short, Sierra logs the trade as buy exiting a trade, and when I should be buying to cover, it logs it as a long entry... I double checked with my broker. My Position is flat. Nevertheless, on my live account, and only on my live account, Sierra is messing up orders. Date Time Of Last Edit: 2021-09-15 17:58:26
[2021-09-15 18:01:54] |
John - SC Support - Posts: 38292 |
You have a missing order fill somewhere. Refer to the following: Help With Daily Profit/Loss Value For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2021-09-15 22:21:46] |
No there is not necessarily a missing order fill. Just refer to the documentation here: Help With Daily Profit/Loss Value Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
