Date/Time: Sat, 01 Mar 2025 01:54:18 +0000
Denali Data Feed.
View Count: 470
[2021-09-15 16:14:27] |
Christopher B - Posts: 8 |
Hi there just wanted to clarify if one needs to have the Denali data feed to access real time data supplied by AMP. Is it a simple case of data feed supplied by AMP and platform supplied by yourselves.? Many thanks in advance Chris Bendall |
[2021-09-15 16:54:56] |
[2021-09-15 17:47:04] |
John - SC Support - Posts: 38292 |
You can get the data from the trading service you are connected to at AMP (CQG or Rithmic), but we will let you know that they both have a lack of historical data and you would be better served by using the Denali Exchange Data Feed. If you are interested in the Denali Exchange Data Feed, then refer to the information here: Denali Exchange Data Feed For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
