Date/Time: Sat, 01 Mar 2025 01:16:40 +0000
Do you need a beta tester for you Level 2 NASDAQ quotes ?
View Count: 492
[2021-09-14 22:50:52] |
GravisHTG - Posts: 306 |
If you need I can be :)
[2021-09-15 15:10:03] |
No we do not need this. We are not even in a position even begin our own testing because we do not even have access to the data feed yet from NASDAQ.
[2021-09-15 16:35:36] |
I was asking after reading this ---- We are finally a step closer, with the upcoming NASDAQ full order by order data feed. We now have a connection to the NASDAQ test facility, to our server in NY4. But we still need to work out, other details like IP address, and username/password for connectivity to the NASDAQ server. Progress is being made, but moving slowly. ----- But if , in the future , you need any beta tester , I am available :) have a good day and I hope you can make this happen before the end of this year ! Date Time Of Last Edit: 2021-09-15 16:35:54
