Date/Time: Mon, 16 Sep 2024 19:16:24 +0000
Bar Numbering Help
View Count: 641
[2021-09-14 21:45:33] |
User968625 - Posts: 260 |
Can you please add the option to start numbering on every session - it is a good idea to start numbering on day session and that's separate from the night session. there has been a couple of requests for that over the years. I think, maybe wrong, it is an easy one.
[2021-09-15 14:23:59] |
John - SC Support - Posts: 34453 |
We have set this as a Feature Request.
[2021-09-15 14:39:08] |
Thanks, John. do you have an idea of a spreadsheet formula for a workaround. you always helped me with that
[2021-09-15 16:53:59] |
In this case, there is not an easy workaround. You would need to modify the code to get this changed. The code can be found in the studies2.cpp file in the ACS_Source directory under your main Sierra Chart folder. Refer to the following for how to create a custom study: How to Build an Advanced Custom Study from Source Code For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2024-02-13 02:20:20] |
User588852 - Posts: 1 |
Hello SC - Is there an update on this FEATURE REQUEST? Its been a couple of years? A setting to start numbering on different sessions without changing the session start time of a chart or switching night session on/off would be particular helpful for learning / following and adapting chart and chart studies to certain Price Action teachings. This would be very helpful and much appreciated!!! Thank you!
