Date/Time: Sun, 16 Mar 2025 17:39:29 +0000
Audible Alarm
View Count: 918
[2021-09-14 19:26:55]
User750920 - Posts: 280
I used to use a DOM that allowed me to set a simple audible alarm in the price ladder and then when the alarm was triggered the alarm price would disappear. Is there a way to do this with Sierra Chart. I already use line alarms - but I want something more simple that is just audible and when triggered it resets automatically so there is no longer an alarm at that price.
Date Time Of Last Edit: 2021-09-14 19:27:15
[2021-09-15 14:06:42]
John - SC Support - Posts: 38678
Refer to the information on Symbol Alerts, it sounds like these are what you are looking for:
Alerts Manager: Symbol Alerts
[2021-09-23 16:34:38]
Thank you for the help. Would love to be able to add an alert like I described in my post #1.
[2021-09-23 17:02:49]
The symbol alert does everything you described in your post. We are curious what you feel is missing?
[2022-08-26 19:33:40]
Do not know how I missed this last response from you John so long ago. But I still cannot get what I was referring to. What I mean is that I set say a limit order on the DOM. When it is elected the Alarm goes off to alert me. It is then automatically deleted. Same would be for any open order on the DOM.
Thanks.
[2022-08-29 09:13:11]
It sounds like you want an alert when an order fills:
Global Trade Settings Windows: Play Alert When Order Filled (Global Settings >> General Trade Settings >> Notifications)
[2022-08-30 00:06:51]
Thank you - everything seems to be working as desired.
