Date/Time: Sat, 01 Mar 2025 02:06:36 +0000
Custom study showing
View Count: 512
[2021-09-14 16:59:20]
User719512 - Posts: 299
Hi, I have seen this occasionally, and usually rebuilding the dll will fix this. But now I can't get this prefix to go away from my study names.
Why would the studies show the "scsf_" prefix in the names in the add custom study dialog? It only happens for some studies, but not all.
imagebad_dll_name.PNG / V - Attached On 2021-09-14 16:57:47 UTC - Size: 17.63 KB - 157 views
[2021-09-14 18:16:21]
John - SC Support - Posts: 38292
Make sure you have the sc.GraphName set for those studies. Refer to the following:
ACSIL Interface Members - Variables and Arrays: sc.GraphName
[2021-09-14 19:04:10]
Hi John, thanks for the reply. I have solved my issue. The code has sc.GraphName in it already, but I had a check in the code that was returning before the sc.Defaults was being called, and that skipped that block of code too early. Moving my check down past sc.Defaults fixed the issue.
THANK YOU for the information, that helped me figure out where my mistake was.
