Date/Time: Sat, 01 Mar 2025 01:38:51 +0000
Not receiving Quotes
View Count: 387
[2021-09-14 11:55:27]
User664240 - Posts: 206
This is the state I found SC in this morning. I've sent the Log as well.
imageice_screenshot_20210914-075409.png / V - Attached On 2021-09-14 11:54:43 UTC - Size: 48.53 KB - 137 views
[2021-09-14 12:06:52]
We know you have had issues with that in the past. It relates to symbol conflicts. We have made a change, to avoid that.
Update Sierra Chart to the current version. Instructions:
[2021-09-14 19:58:35]
It appears that SC looked at all my symbols and RE-downloaded the historical Data for the correct format. Hopefully this puts an end to these issues.
Date Time Of Last Edit: 2021-09-14 19:58:54
