Date/Time: Tue, 23 Jun 2026 07:05:10 +0000
Can´t get data older than when I connect
View Count: 667
[2021-09-14 10:52:33]
User215298 - Posts: 20
Background:
- with oneupTrader evaluator
- subscribed with Denali & opened an account with AMP to be a non-professional
- settings in tool should be all good (days to download)
- performed the Edit -> Erase and Download function
however I still can“t get correct data (I have like one candle in 2020 and then correct candles since when I connect to the platform)
What could be the issue?
Thank you!
[2021-09-14 14:30:56]
John - SC Support - Posts: 46822
Go through this section first if you are wanting Intraday data:
Historical Intraday Data (Missing Data / Download Errors / Viewing More Data): Instructions to Download/View More Historical Intraday Data
Or, go through this section if it is Daily Historical data you want:
No Historical Chart or Blank Chart | Historical Chart Not Updating | Missing Historical Chart Data
[2021-09-14 16:03:48]
You are not receiving data from the Denali Exchange Data Feed because you are not connecting to a what is considered a live funded account.
The reason you are not getting real-time or historical data in this case from the CME Group of exchanges is that you activated the Non-Professional exchange fees, but you have not verified in the last month that you have a live, funded, futures trading account, which the CME needs in order to allow you data at the lower priced fees.
Refer to the following for instructions on how to connect once a month to your *live funded* trading account to qualify for the lower-priced exchange fees:
If you do not have a funded trading account or one with a supported trading service, then refer to this solution:
Easy Solution to CME Funded Trading Account Requirement
We recommend using the above solution in any case to avoid this problem in the future.
