Date/Time: Sat, 01 Mar 2025 01:42:44 +0000
Display K3 spreadsheet value as text on chart (just like the countdown timer for exaplame)
View Count: 557
[2021-09-14 07:59:08] |
VolTrader73 - Posts: 136 |
Hello. I searched for this but found only "Text display for study" and "valuetextonchart" study in 2 posts. the valuetextonchart study , I have downloaded but do not know where to download to and how to load it as a study for the chart. I just want to have the K3 cell value (or any other if needed) to display on the chart like the countdown timer for example. Please advise. EDIT: I managed to plot it on chart using the "Text display for study" but am not sure if this is the right way. First, changing horizontal and vertical position in the study settings dose not affect the position of the text. Second, choosing auto coloring based on negative/positive dose not change the color. Should I use the valuetextonchart study instead ? if so, I downloaded that study but cant find it in the studies available for the charts. Date Time Of Last Edit: 2021-09-14 08:34:27
[2021-09-14 14:03:40] |
John - SC Support - Posts: 38292 |
The Text Display for Study is the right study to use for what you are wanting to do. The position values should change the location of the study. So changing the Horizontal Position from Left to a value of 100 should move the text display to the right side of the screen. The other study you are referencing is not one of our studies, so we can not help you with it except to tell you that 3rd party studies need to be put in the Data folder under your main Sierra Chart installation. From there you can access it through the Custom Study button. Refer to the following: Chart Studies: Chart Studies Window For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
