Date/Time: Sat, 01 Mar 2025 01:40:21 +0000
Mass Update Studies
View Count: 514
[2021-09-13 19:27:51]
quin6 - Posts: 22
Hello! Wishing you well.
I use A lot of VWAPS when trading
I have to go into the studies menu and update the date/time setting in each vwap that I have up, everyday.
Is there a way to mass select / mass update all my vwap's date and time at the same time?
This would help tremendously...
Thank you!
[2021-09-13 23:01:14]
John - SC Support - Posts: 38292
The only option that accomplishes this is the Chart Linking, which allows for Studies to be linked. The one thing to be aware of though, is that this linking puts the same studies on the charts that are linked, as well as having them setup the same way. So you have to be careful when using it to ensure that it is what you want to do.
Refer to the following:
https://www.sierrachart.com/index.php?page=doc/ChartSettings.html#LinkNumber
[2021-09-14 00:04:39]
GravisHTG - Posts: 306
Maybe this can help
By using Volume By price Study and the vwap from it , its always updating and you can get a new vwap every X min as you wish. And even have multiple VbP at the same time.
Date Time Of Last Edit: 2021-09-14 00:23:26
[2021-09-14 22:41:10]
quin6 - Posts: 22
Hey Gravis, I find that the Calculations are different and do not accurately load when I calculate vwaps from the Volume by Price study.
That was my experience in the past, I could be wrong I'll retry!
[2021-09-14 22:45:46]
if the vwap have too much of a difference , try to put it on a smaller time frame and Overlay it to other charts.
