Date/Time: Sat, 01 Mar 2025 01:28:13 +0000
Replay chart doesn´t work
View Count: 813
[2021-09-13 18:25:41]
User277026 - Posts: 4
Dear Sir or Madam,
I experience an issue with Replay Charts in Sim with NQ (just use that and nothing else) since today (but didn´t use it for a few days).
Nothing happens after pressing Replay Charts ...
I updated Sierra Chart and downloaded all data new.
All real-time data are running ok (CQG).
I couldn´t find a solution in the community.
Can You help?
Thank You!
Kind regards,
Dirk
[2021-09-13 21:39:41]
We see you are using CQG. We cannot help with CQG data. Use the Sierra Chart Historical Data Service when replaying charts:
[2021-09-13 23:12:33]
John - SC Support - Posts: 38292
It sounds like your issue may be that the Replay Chart window is not coming up when you select Chart >> Replay Chart >> Replay Chart (Control Panel). If this is the case, then refer to the following:
Replaying Charts: Chart Replay Window Not Visible
