Date/Time: Sat, 01 Mar 2025 01:57:13 +0000
volume profile for current session of historical data
View Count: 606
[2021-09-13 15:29:00]
User248599 - Posts: 3
I use Volume by Price study. Also I use downloaded history data for backtesting my strategy.
If I use Visible Bars in mentioned study volume changes dynamically from bar to bar when I move from the right to the left.
But the problem is that my visible chart's area length is for couple of days
and I need volume to be displayed in the same dynamic way for history data but only just for the current session (or day), not for both days as per my visible chart
Is that possible?
[2021-09-13 16:23:10]
John - SC Support - Posts: 38292
The only way to do this would be to change your Chart Bar Spacing so you only have displayed the amount of time that you are wanting in the chart, rather than having multiple days displayed. Refer to the following:
Working With Charts: Changing Bar Spacing
