Date/Time: Sun, 08 Sep 2024 00:07:48 +0000
First In First Out orders
View Count: 1596
[2014-03-25 00:10:41] |
AC94667 - Posts: 5 |
Is there a way to set the execution of exit orders on SC to First In First Out (FIFO)? I like to scale in with limit orders on my position but the first orders to get exit are the last ones I entered with in other words the way it is right now is First In Last Out, and Last In First Out Thanks |
[2014-03-25 01:55:35] |
User63439 - Posts: 83 |
look Trade - general trade settings - then you find scale in and out and set it how you like. hope i could help |
[2014-03-25 22:22:14] |
Ultimately what it sounds like you are referring to is the FIFO/LIFO logic used for order fill matching which is used to create the Trade Position Average Price. This is explained in detail here and how to change this logic: https://www.sierrachart.com/index.php?l=doc/doc_TradeActivityLog.php#OrderFillMatchingMethods Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-03-25 22:22:34
